VTR1000F 2001 Blue
Moderator: VTRDark
purgeraptor
VTR1000F 2001 Blue
Post by purgeraptor »
NOW SOLD
Unfortunately, my wrists and neck are getting worse, so I'll be selling off my bikes with low bars in the Spring :(
So, if anyone here would like an excellent condition, low mileage, fully sorted Storm, send me a message.
I'll be advertising the bike widely in Spring, but thought I'd give members here a chance to buy in advance at a lower price of £2000 (no offers).
I'll add to the For Sale section later.
Honda VTR1000F
GN51 LUW
9,871 miles
MOT until 23-8-24, no advisories.
V5 in my name at my address.
Registered 1 Sept 2001
Location Reading RG4
Things I have done:
(see my 'Welcome from Reading' thread in the 'Welcome' section for detailed pictures and commentary on the work I've done in my 1 year of ownership)
Venhill front braided brake lines and new fluid 7-9-23 @9,750m
Venhill braided rear brake line 5-3-23 @9,190m
Clutch lever standard shape black Heltec 24-2-23 @9,190m
Braided HEL clutch line 24-2-23 @9,190m
Z1000SX radial front brake master cylinder 23-2-23 @9,190m
Manual fuel tap from ZZR11 4-2-23 @9,190m
Vacuum OEM fuel tap fitted with TRK seal kit...but still drips fuel through when it is supposed to be OFF 4-1-23 @9,190m
De-greased and cleaned indicator switch internals 26-1-23 @9,190m
New Yuasa YTX12-BS 25-1-23 @9,190m
Carbs balanced and checked internally, perfectly clean: Mains 175F / 178R, Pilots #48, Idle screws 2.25F, 2.5R 22-1-23
Front carb vacuum gauge stub fitted 21-1-23
Paddock stand axle bobbins fitted through rear axle 20-1-23
Manual CCTs fitted, 7mm chain slack adjustment 19-1-23 @9,190m
Valve clearances checked and in spec 18-1-23 @9,190m
NTN taper head bearings fitted 21-12-22 @9,190m
Fork brace fitted 21-12-22
Mac split SS exhaust flanges and new OEM nuts fitted 16-12-22
K-Tech 0.9kg/mm linear fork springs fitted, Motul synth fork oil 7.5w, 130mm air gap. 13-12-22 @9,190m
Spark plugs NGK DPR9EIX-9 fitted 23-11-22 @9,190m
Air filter HF1909 fitted 23-11-22 @9,190m
Shindengen FH020AA MOSFET RR fitted with heavy guage wiring to stator and direct to battery via 30A fuse 20-11-22
Spyball alarm / immobilizer removed 17-11-22
Oil filter HF303 and Shell Advance 15-11-22 @9,190m
Seat fixing hoops removed 14-11-22
GRmoto cans fitted 16-11-22
Optimate lead fitted 16-11-22
The tyres are almost un-used Michelin PR3 tyres, but were fitted in Dec 2015 by previous owner before he laid the bike up. No cracks or hardening, and 'feel' fine to me, although I was going to upgrade them to PR6s before next Summer if I was keeping the bike.
Bike will come with following spares:
Supersprox Stealth 42T rear sprocket, new never fitted as OEM sprocket is still perfect.
The standard exhaust cans in excellent condition
Standard front brake master cylinder and lever in excellent working condition.
OEM CCTs which were working perfectly, and only changed as a precaution.
Spare OEM vacuum fuel tap from Mac (not tested).
Original seat fitting hooks.
Original clutch lever.
Original progressive fork springs.
Original fork protectors
Spare OEM flasher relay (wasn't needed once the switch was cleaned out)
New #48 pilot jets...discovered carbs already had #48s fitted.
Any interest or questions, message or post here
Cheers,
Mark
Re: VTR1000F 2001 Blue
That really is a nice bike :thumbup:
purgeraptor
Cheers :thumbup:
The bike looks good mate👍 GLWS
purgeraptor
Thanks!
purgeraptor
Bike now sold subject to collection.
I re-fitted the standard cans, so have the 14 month old GRMoto cans and link pipes for sale.
Also a new 42T Supersprox rear sprocket that I never fitted.
Also have the OEM ACCTs I removed when fitting MCCTS if anyone wants those to experiment with or do the stopper mod to? They only have 9871 miles on them and were woking perfectly when removed.
Will post separate for sale posts in this forum for the above items.
Thanks for all your help as I went through the bike last year in making it perfect :thumbup:
Cheers,
Mark
