Front brake line ‘Race’ set up
Re: Front brake line ‘Race’ set up
Donut 77 wrote: Fri Sep 01, 2023 9:17 pm Thanks. I did end up adding the second P-Clip and adapting the horn bracket. Yes I did try the full range of movement and all seems ok 👍
I wish I could pull a wheelie 😆
Good man :thumbup:
Donut 77
Post by Donut 77 »
For anyone reading this in the same situation as me, with off the shelf race brake kit (2 separate lines up front)…
In the end, I swapped back to the long hose to Left, shorter hose Right and I went back to the original Honda bracers mounted on the fork legs too. The P clips were holding it too near the forks and on hard braking, both lines were bending and fouling on everything..
P clips came in useful up top
Good job I’m not in a rush…
No longer in the B154-M club.
Donut 77
Post by Donut 77 »
For anyone reading this in the same situation as me, with off the shelf race brake kit (2 separate lines at front)…
In the end I swapped back to the long hose LHS, shorter hose RHS and I went back to the original Honda bracers mounted on the fork legs. The P clips were holding it too near the forks and on hard braking, both lines were bending and fouling on everything..
