Problem with starting engine
GARID
Post by GARID »
Hi i have problem with starting the engine, i can easily push start but it will not work with starter button making strange noise
Re: Problem with starting engine
Starter motor...
Head to ebay & find one from a CBR or Blackbird. Same part but located on rear of the motor so normally much cleaner than VTR ones.
GARID
Post by GARID »
MacV2 wrote: Tue Aug 15, 2023 5:55 pm Starter motor...
I cleaned it up and it doesn't help
GARID wrote: Tue Aug 15, 2023 6:09 pm
Did you take it apart or just clean the outside ?
If not the starter motor then have a read of this: viewtopic.php?t=20849
tastethefloor
Post by tastethefloor »
the issue is the starter clutch beyond the freewheel
GARID
Post by GARID »
MacV2 wrote: Wed Aug 16, 2023 5:10 am
took it apart and cleaned by dissembling
tastethefloor
the problem isn't in the starting engine, the problem is in the starting clutch that is worn
