Threadlocker on brake calipers bolts?
Acke
Post by Acke »
Hello,
I removed my front brake calipers due to servicing the forks.
When unscrewing the caliper bolts i noticed a white residue/dust on the bolts. Same with the pad pin, was a noticeable click when I managed to unscrew it.
Is this threadlocker? Should i get the blue stuff or is properly torqueing with a tool enough?
New brake pads, which ones would you pick?
https://www.baboon.eu/sv/reservdel/hond ... 0000316666
https://www.touring.se/touringbutiken/b ... elagg-sbs5 - 23-622HS
Re: Threadlocker on brake calipers bolts?
White stuff is probaly just corrosion a small dab of thred lock wont go amis...
Pads my go to is SBS Road...
https://www.ebay.co.uk/itm/383266817283
MacV2 wrote: Sat Jun 10, 2023 7:32 am White stuff is probaly just corrosion a small dab of thred lock wont go amis...
Yes. But you run into stuff sometimes ...
:wave:
tony.mon wrote: Sat Jun 10, 2023 3:43 pm
:wave:
Not since I killed Ole Red... I didn't have SBS pads then... All the others had nothing to do with stopping in time... :lol: :lol:
