Steering damper
Moderator: VTRDark
Steering damper
Anyone got a damper and fitting kit knocking around they don't want? Definitely need one for the storm asap
Re: Steering damper
mine was very stable and never needed one. check other things first maybe?
Re: Steering damper
Its because it's jacked up and I'm riding it at high speeds on bumpy roads, would give me a bit more confidence with a damper on there to stop the bars flapping around when I'm pushing hard!
Re: Steering damper
Maybe you should "un-jack" it a bit. Once you have gone too far a damper will not fix the issue. This issue is what caused the frame ears to be added by Spondon which didn't work. The only way to get the bike stable again was to lower the rear ride height. The max is 5mm anymore and you are asking for issues.
- freeridenick
Re: Steering damper
What Hawk says. Also don't drop the forks through the yolks more than 8mm.
Re: Steering damper
Dave has a high bar conversion on it as well so that may be causing some of the issues, with the weight off the front.
Re: Steering damper
out of interest, is it jacked up at the rear or do you have shorter blade forks?
- freeridenick
Re: Steering damper
The 'Blade forks, set without any drop-through, give basically the same rake and trail as 5mm drip-through on standard forks. I'm pretty sure I remember that correctly. It was a while ago when I worked it all out though.haynesjones66 wrote:out of interest, is it jacked up at the rear or do you have shorter blade forks?
Re: Steering damper
i have 95 blade forks on mine. havent ridden it in anger yet but pootling round the estate it turned in quicker than my old standard storm
