Fuel light
MasterBlaster
Fuel light
Post by MasterBlaster »
Right, new bug here. I know this subject may have been done to death, but the fuel light on my '99 'storm (13ltr tank) is not working.
Have tested the light (good) and replaced a few thermistors. Still no results. I have got the multimeter out and have found 2.0 ish in the 20K Ohm setting with fuel onboard.
This drops to 1.50 is when the level leaves the thermistor is uncovered.
Are these the right readings, and could I possibly have another problem in the instruments?
Thanks in advance, had my bike two years and bloody love it.
Thanks in advance, chaps.
jchesshyre
Re: Fuel light
Post by jchesshyre »
Might be a stupid question but you do have it connected at the connection under the fuel tank don't you?
Re: Fuel light
jchesshyre wrote: Wed Apr 05, 2023 2:00 pm Might be a stupid question but you do have it connected at the connection under the fuel tank don't you?
i ran outa fuel for that very reason :lol: :lol:
Re: Fuel light
For clarity, the connection is just behind the rear fuel tank pivot bracket, ahead of the battery and under the seat.
You can't plug it into the wrong connector, they are all different, except for two connectors that are the same. One is the fuel tank sensor, as above, the other is located beside the engine on the left hand side where the ignition pickup connects into the loom.
In practice, you can't get these the wrong way round, the lead won't reach the wrong socket, and if you did, the engine wouldn't run.
MasterBlaster
Re: Fuel light
Yes, It is connected up fine, the light works when shorted out. However, various replacements have failed to work when connected up and on low fuel. I have recently got another replacement, and still no results.
Could it be the instrument panel?
Re: Fuel light
MasterBlaster wrote: Tue Apr 25, 2023 9:40 pm
The earth (ring connector) connections on the rear of the panel can become corroded so remove, clean and refit. See if that helps.
MasterBlaster
Re: Fuel light
tony.mon wrote: Wed Apr 26, 2023 3:28 pm
Thanks, will try that.
