Hi from Reading
purgeraptor
Hi from Reading
Post by purgeraptor »
Picking up this tidy 9K miler today.
Looking forward to joining in the forum discussions :D
Re: Hi from Reading
Hello and welcome to the forum.That is tidy looking bike :wave:
Re: Hi from Reading
Welcome aboard :thumbup:
It looks like a nice low mileage bike you have found yourself there,
Re: Hi from Reading
Nice looking bike. Welcome to the club
purgeraptor
Re: Hi from Reading
Thanks!
Got it home, rides like a new bike, although I find the forks a bit soft. I'll up the preload.
Also discovered the RR is faulty, over charging. I'll fit a Shindengen MOSFET RR. Luckily the stator coils are fine.
Just fitted these GRMoto cans for more thump :D
Re: Hi from Reading
That should help her breath a bit better 8)
They look good,
purgeraptor
Re: Hi from Reading
Fitted the Shindengen FH020AA MOSFET RR, with massive gauge wires, direct to the battery via a BIG in-line 30A fuse holder, and direct to the yellow stator wires, cutting out the stator connector just behind the tank.
All working lovely, 14.6V at high revs and 13.6V at tickover with headlight on. Doesn't change much with headlight off, just 0.2V more....which is good regulation.
purgeraptor
Re: Hi from Reading
purgeraptor
Re: Hi from Reading
purgeraptor
Re: Hi from Reading
All fits neatly under the battery cover and the tail fairing
purgeraptor
Re: Hi from Reading
purgeraptor
Re: Hi from Reading
purgeraptor
Re: Hi from Reading
Also expunged the horrific Spyball alarm and immobiliser :lol:
purgeraptor
Re: Hi from Reading
This was the corrosion behind the OEM RR where the earth wire eyelet attaches.
Maybe that was the original problem if the VTR RR dumps current through that auxiliary wire rather than the ground wire in its connector?
Anyway... the Shindengen is a much better RR, so a worthwhile upgrade.
Re: Hi from Reading
Well done mate 👍🏻
