Get the up swept look for a fraction of the cost of a set of Hi level link pipes...If you can find a set...
7 sets in stock, you get two brakets & 4 bolts, 2 cap head, 2 pan head.
£40 + shipping £2.50 2nd class, £3.50 1st class...UK mainland only but happy to ship overseas extra postage cost will be required.
Easy to fit. Loosen the exhaust clamps on the links, undo the exhaust straps ( un bolt on std cans...) un bolt the hanger from the subframe. Bolt the plate to the subframe, with the pan head bolt to the front, bolt the hanger back on using the origonal bolts into the threaded holes on the bracket. Lift the can up to reatach the straps...Tighten up the exhaust/link pipe clamps...Repeat on the other side... Stand back & admire your work...30mins job done.
Exhaust Hanger Angel Plates.
Moderator: VTRDark
You do not have the required permissions to view the files attached to this post.
Re: Exhaust Hanger Angel Plates.
5 sets left...
Two sets left only...
