De-pin electrical plugs?
pat_986
Post by pat_986 »
Hi all,
Does anyone know the correct way to de-pin the electrical plugs, or know what brand plugs they are?
The previous owner converted to renthal bars and concealed the wires inside the bars and top yoke.
I'm converting back to clip ons and I believe this is the only/best solution on free the wires.
pat_986
Re: De-pin electrical plugs?
Post by pat_986 »
pat_986
Post by pat_986 »
You just push in a tiny jewellers screwdriver in the back of each pin to release them.
You can buy a cheap kit to repair spectacles/glasses.
bigbadjonno
Post by bigbadjonno »
A good sturdy safety pin will do it, push it down the side of the terminal to depress the locking tab, then withdraw it from the rear of the plug.
Failing that, there's an abundance of "terminal removal" or "terminal ejector" tools on Amazon or eBay for not a lot of money.
pat_986
Post by pat_986 »
Thanks very much.
I just wanted to check as when I've recently done the same on my VAG car, the procedure and tool are both quite precise.
Pat
