Exhaust Recommendation for Firestorm
ItsaKeeper
Re: Exhaust Recommendation for Firestorm
Post by ItsaKeeper »
I'm going to hold on to the dream that I can get a bargain akra/moriwaki...I'm dreaming big :lol:
ItsaKeeper wrote: Mon Mar 21, 2022 11:59 am I'm going to hold on to the dream that I can get a bargain akra/moriwaki...I'm dreaming big :lol:
I like your style :thumbup:
Def@st
Post by Def@st »
Have a look at Roads exhaust, really well made, cheap and with omologation (at least here in Italy)
https://www.roadsitalia.com/it/1400-hon ... oadsitalia
They are on my to-do list with a Dyno stage 1, just after the CCT stop mod and handlebars raising.
For the V2 i reccomend not to go with carbon models, a couple of friends used to have cracking issues (also with different brands). Titanium is the way to go!
dont hold your breath :eek2 i looked for 2 years until a gent on here sold me a set :clap: :clap:
Bigp
Post by Bigp »
Mine came with a set of scorpions and they do sound good
#MOOSE90
Post by #MOOSE90 »
Carbon danmotos stupid loud sound great
#MOOSE90 wrote: Mon Mar 28, 2022 9:06 pm Image
I'm sure it is LOUD 8O :lol:
#MOOSE90
Post by #MOOSE90 »
Straight threw cans mate they have the volume control built in but haven’t got the cabling to open and close baffles so they constantly open 😂
DJWALKER
Post by DJWALKER »
There's a member got a mori system but you'd have to ask if he's selling, look on my thread in bike chat tool kit good luck bud
Robert j
Post by Robert j »
I just fitted some black widow pipes £230 delivered good quality and sound good
ItsaKeeper
Well I (eventually) followed Macv2's advice and sourced a Moriwaki Ti full system from Japan :thumbup:
Can someone help with the clamp size from the existing rear link pipe to the Moriwaki collector? I'll get a Mikalor W5 marine grade SS clamp but was unsure of the size :confused The Moriwaki connector bit is 51mm without the rear link pipe inserted so that must be the maximum diameter?
So I was thinking 47-51mm clamp should do it.
Also I don't think I need a graphite gasket that connects the moriwaki collector bit to the honda rear link pipe?
ItsaKeeper wrote: Thu Mar 23, 2023 4:46 pm Well I (eventually) followed Macv2's advice and sourced a Moriwaki Ti full system from Japan :thumbup:
If it's a full system, surely you don't need to attach the new system to the standard downpipes?
You wouldn't use any of the standard system.
Mori full systems use the stock rear down pipe. Check the size of the existing clamp and order the same.
You need the graphite gasket as per stock.
ItsaKeeper
Right I'll order a 51mm clamp and an OEM graphite gasket :thumbup:
freeridenick wrote: Thu Mar 23, 2023 9:47 pm Mori full systems use the stock rear down pipe. Check the size of the existing clamp and order the same.
I never knew that :thumbup:
Chris
