wont start
northmanuk
wont start
Post by northmanuk »
well down to last thing to do get the bugger running she made noise sounded like she was going to run but died do the carbs take long to fill ( my gsx 1100 takes ages fromm empty carbs to start up) so first thing i did was put battery onto charge some ignition systems take 12v to fire
then its dow to
a fuel getting through
b full charge in battery
cgood spark
my hands are very bad at moment so i havent taken plugs out yet
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaggggggggggggggghhhhhhhhhhhhhhhhhhhhhhhhhhhhh :)
Re: wont start
Apply vacuum to he petcock with either a mity-vac or just a piece of hose and some suction for a few seconds and let the carbs fill before you try to start the bike.....with dry carbs it will take a while just cranking it for the carbs to fill :thumbup:
northmanuk
Re: wont start
cheers hawk will try tomorrow
law
Re: wont start
Fingers crossed it's just a slight hiccup,
neil
Re: wont start
Post by neil »
Make sure pipes go to correct connection on tank, easy to mix them up
redvtr
northmanuk
Re: wont start
thanks all day off from stress today but i will start investigation tomorrow :)
northmanuk
Re: wont start
the answer to no start the kill switch was on 2003 model the bike spins over but no fire but she ranb so ill fill her with proper coolant not water and set tick over which is very low sincew i had to altter cables to take of carbs
im going to order new plugs too :beer:
Re: wont start
Kill switch oops :roll: :roll:
northmanuk
Re: wont start
double oops but at least i stripped her and rebuilt her without any physical help but loads of written help thank you all especially chris who gives lots of encourage ment :D
Re: wont start
northmanuk wrote: Tue Mar 08, 2022 12:20 pm the answer to no start the kill switch was on 2003 model the bike spins over but no fire but she ranb so ill fill her with proper coolant not water and set tick over which is very low sincew i had to altter cables to take of carbs
Excellent news, I'm pleased for you it was something simple :thumbup:
Well done in getting it all back together and running again :clap:
northmanuk
Re: wont start
yahoo starts on the button idles and reves nicely sounds like a small dumper truck not as load as a harley but a nice thump thump new plugs new oil and filter new coolant new air filter readyfor the summer five month off my life gone on her only fairing to put on .im even begining to like her (blush lol,) :D
mjvw
Re: wont start
Post by mjvw »
Great stuff happy days :clap: :thumbup: :thumbup:
Storming About :thumbup:
