bolts
northmanuk
bolts
Post by northmanuk »
does anyone know the dia and thread on lower yoke bolts
they look like m10 which usually means fine thread but i dont know the pitch maybe 1.75
cheers i havent broke owt yet (well it is only monday)
Re: bolts
northmanuk wrote: Mon Dec 13, 2021 6:39 pm does anyone know the dia and thread on lower yoke bolts
BOLT, FLANGE (10X35)
96400-10035-07
https://www.ronayers.com/oemparts/a/hon ... ering-stem
northmanuk
Re: bolts
cheers mac i just orderd two and took chance the firms fine thread was ok
Re: bolts
Didn't think they were a fine thread, could be wrong though.
They don't need a high torque and there's plenty of material to grip to, so enough threads can engage.
IanB
Re: bolts
Post by IanB »
Pretty sure they're standard M10 coarse, which means a 1.5mm pitch (1.75mm is the standard pitch for M12 coarse). Coarse threads are the right choice for in a soft material like aluminium alloy.
Ian
Ian
All of the gear, no idea...
northmanuk
Re: bolts
i tried to screw in 10mm bolt wont work i believe japs dont use coarse thread on larger bolts dont ask me why but normal bolt only just moved into thread so unless you force it stripping bolt and bolt hole its no go
Re: bolts
Just measure how many threads there in a 10mm length of the old bolt, that will tell you the pitch. If there are ten then it's 1mm pitch, etc
IanB
Re: bolts
Post by IanB »
The Japanese certainly do use standard coarse threads; I have just replaced the bolts in the top yoke with standard M8 studs - they screwed straight in.
What does help is to gently run a tap through the threaded hole. You should feel the difference between a tap cleaning corrosion and crap out of a thread and a tap actually trying to cut a different pitch. A tap will remove any fouling, screwing a bolt in will just compact it.
Ian
Ian
northmanuk
Re: bolts
yup 6-8mm are normal thread. 10 and above fine thread please believe before you wrack through lower yoke bolts and please dont run a tap through them. i worked as motorcycle fitter and know 10mm bolts are fine thread
merry Christmas all and happy new year :D
