Blinking indicators
lumpyv
Blinking indicators
Post by lumpyv »
Hello, my front offside indicator does not work the rear os one goes at 20 to the dozen, nearside both work correctly.
It's not the bulb, I've changed the relay and I've checked the earth's.
I can't think anythings happened to the wiring cos it hardly goes anywhere, never in the rain and it lives in a garage, all cosy and clean.
Can't really be anything else but the wiring can it??
Re: Blinking indicators
It sounds as if there is no power getting to the front O/S indicator. Check with multi- meter to confirm first, then I would say it's probably a switch problem,
Sent you back a PM but as Chris says either a switch issue or wireing.
Check the conections to the front O/S indi, the female side of the bullet can open up & get loose. Check for corosion, green muck.
Have you changed the bulb ? Is it the correct wattage...Try swapping the font bulbs over side to side & see if its the same or the issue swaps sides.
I would strip & clean the switch, dirt & grime build up & 20+year old grease.
If you have any contact cleaner give the switch a good squirt & work the switch on & off. Then try it again if that improved things then strip & clean...
Mac
as has been said....most likley the conectors to the from indicators, the ones up near the headlight.
lumpyv
Post by lumpyv »
I'm on it :thumbup:
Been doing a shed base all day and quite knackered :lol:
lumpyv
Post by lumpyv »
10/- postal order to whoever said bullet connectors under the fairing :thumbup:..
That's where the problem was...
:D
lumpyv wrote: Sun Jun 13, 2021 6:33 pm 10/- postal order to whoever said bullet connectors under the fairing :thumbup:..
:D
Glad to hear you got it fixed :thumbup:
:D
''Check the conections to the front O/S indi, the female side of the bullet can open up & get loose. Check for corosion, green muck.''
Me...
Still look on the bright side you have a spare indi relay now... :thumbup:
lumpyv
Post by lumpyv »
:thumbup: :P
