VTR fuel and vacuum lines
nachtjaeger13
Post by nachtjaeger13 »
Does anyone know where the tube that has a plastic reducer fitted to it locates to?,I've noticed that this plastic piece is missing from the hose,what is the part called?
Thanks
Re: VTR fuel and vacuum lines
It goes to the smaller stub on the underside of the tank.
It isn't connected at the other end as it's a vent.
I think it's just a reducer, there's no special name for it.
nachtjaeger13 wrote: Thu Jun 03, 2021 1:07 pm Does anyone know where the tube that has a plastic reducer fitted to it locates to?,I've noticed that this plastic piece is missing from the hose,what is the part called?
Thanks
That one would be the tank breather. If you have a little stub of black tubing just pull that off & fit the long tube directly on the stub...
JOINT, TUBE 19126-KM1-010
No.4
https://www.ronayers.com/oemparts/a/hon ... /fuel-tank
nachtjaeger13
Thanks for the info,very much appreciated
