Draining fuel tank
Wilky811
Draining fuel tank
Post by Wilky811 »
Hi guys. I need to drain the fuel tank but don't want to syphon from the filler cap. I'm assuming I can drain via the petcock but have no idea how to do it. Any help appreciated
Re: Draining fuel tank
Wilky811 wrote: Fri Apr 23, 2021 4:31 pm Hi guys. I need to drain the fuel tank but don't want to syphon from the filler cap. I'm assuming I can drain via the petcock but have no idea how to do it. Any help appreciated
16 0r 19ltr ?
16 is syphon only unless you can put a vacume on the petcock & have pipes attached to the outlet's draining into your container...You could do that by sucking on the vac pipe but its gonna take you a long time...
19ltr just pull the fuel pipe off the petcock & it will flow out.
I syphon by using a lrg syring to do the sucking on a a small bore pipe. Takes a while but it works.
Big question is how much fule is in the tank ?
Wilky811
Post by Wilky811 »
It’s a 16l tank, full. Cheers, I’ll get started early tomorrow
You can use a syringe to generate the vacuum to open the fuel tap
Suck on the vac line then use Mole grips to clamp the line near the tap when the fuel starts flowing.
Wilky811
Post by Wilky811 »
Cheers lads. Sorted
