hard clutch
Keeping you informed of what's happening with the forum, updates, downtime etc.
jzape2005
hard clutch
Post by jzape2005 »
Hello, I apologize, if it is not the correct section. I explain a little my problem, after doing about 100km, the clutch becomes very hard, the lever is difficult to operate, I end up with the painful hand of using it, any help? thanks from Catalonia, Spain.Image
Enviat des del meu Redmi S2 usant Tapatalk
Re: hard clutch
I would start by removing the clutch lever (by removing that it stops the slave cylinder piston being pushed out), then remove the front sprocket cover with clutch slave cylinder still attached to it, suspend it up out of the way leaving the hose still attached. See if that needs a good clean in behind there and while your are there remove the clutch push rod and check it's not bent, give that clean and lubrication before refitting.
jzape2005
Re: hard clutch
Post by jzape2005 »
okay. Thanks for your time. I have reviewed the clutch pump, it seems that it is fine, the lever is fine, there are no strange friction, I need to look at the hydraulic piston that goes in the engine and the rod that acts in the clutch, to see if I can this end of week, a greeting and thanks, I will report what you see when disassembling.
Re: hard clutch
The hydraulic piston that goes in the engine as you say is what we call the "Slave cylinder" The clutch pump you have reviewed we call the "Master cylinder".
Just remember to remove the clutch lever at the handlebars before removing the sprocket cover and slave cylinder,
jzape2005
Re: hard clutch
Post by jzape2005 »
I hope excuse my English, it is quite bad, the translators too, it must be difficult for you to understand my words.
I am grateful for your patience, greetings
Re: hard clutch
jzape2005 wrote: ↑Thu Jul 09, 2020 10:56 pm I hope excuse my English, it is quite bad, the translators too, it must be difficult for you to understand my words.
:) providing you can understand my words then all is good :thumbup:
jzape2005
Re: hard clutch
Post by jzape2005 »
:thumbup: :thumbup:
jzape2005
Re: hard clutch
Post by jzape2005 »
:) providing you can understand my words then all is good Image
Hello, I think I have found the problem. I have removed the clutch lever, cleaned and reviewed, the tube that goes to the slave cylinder is rubber, it seems that over the years it has deteriorated. I have bought a new line and will install it when it arrives from U.K. I will comment on the result when I install it. A greeting.
Re: hard clutch
Best of luck, I hope it goes in ok.
The bleeding of has a reputation for being a bugger, but there is lots of advice on the best way, so crack on πŸ‘πŸ˜„πŸ˜„πŸ˜„πŸ‘πŸ‘πŸ˜·
Re: hard clutch
jzape2005 wrote: ↑Wed Jul 15, 2020 11:22 am
Hello, I'm glad you have found a possible cause of this problem :D
I hope the new clutch line will fix it,
jzape2005
Re: hard clutch
Post by jzape2005 »
Hola, eso espero Chris, de momento paciencia hasta que Royal Mail me envie el pedido.
Mi mano lo agradecera, la ultima ruta fue dura para ella
jzape2005
Re: hard clutch
Post by jzape2005 »
jzape2005 wrote:
sirch345 wrote:
jzape2005 wrote: ↑Wed Jul 15, 2020 11:22 am Hello, I think I have found the problem. I have removed the clutch lever, cleaned and reviewed, the tube that goes to the slave cylinder is rubber, it seems that over the years it has deteriorated. I have bought a new line and will install it when it arrives from U.K. I will comment on the result when I install it. A greeting.
Hello, I hope so Chris, for the time being patience until Royal Mail sends me the order. My hand will thank you, the last route was hard for her
Re: hard clutch
I feel your pain! I used to own a Laverda! πŸ˜‚πŸ˜‚
jzape2005
Re: hard clutch
Post by jzape2005 »
Richard wrote:I feel your pain! I used to own a Laverda! ImageImage
Hello, It's true, I had a laverda 750 sf 2, I know what a men's clutch is, I will always regret having sold it.
jzape2005
Re: hard clutch
Post by jzape2005 »
I think that after a good review of the entire system, I have found the solution. change the clutch hose, put a new one, review the slave cylinder, the rod that pushes the clutch discs, I have also changed the discs. Taking advantage of the fact that the lid was off, I changed the seals of the water pump, which was losing a bit. the brass bushing that goes on the clutch lever and to finish the master cylinder rod. I have managed to make it go a little better, at least when putting gears it no longer does the typical cataclonk
