Caliper and mounting bolts
bigtwinthing
Post by bigtwinthing »
So do I fit new high grade s/s caliper bolts with copper slip and torque to normal, or lock tight? I do know alloy and s/s can corrode together.
I also have s/s mounting bolts to secure the callipers to the Fork legs, is that a good idea?
Ta in advance BTT
Re: Caliper and mounting bolts
I'd torque them up to spec dab of locktight... I strip & clean me callipers every six months so they dont have time to corode...
There is an anti seize compound for ally but you obviously can't use both...
https://www.ebay.co.uk/itm/Sealey-Alumi ... Sw42JZFNEp
popkat
Post by popkat »
don't use copperslip and torque to normal, it'll be too much and the bolts may stretch or snap, infact just don't use copperslip.. I didn't use anything on mine and don't remember there being locktight on the threads to start with, they don't do up as tight as you might think. if you do then use a semi permanent locktight.
bigtwinthing
Thanks Chaps.
jchesshyre
Post by jchesshyre »
I may be wrong, but I thought the OEM bolts come with locking compound already on them, which is why Honda say to replace them each time you remove them. Instead of replacing them, a clean and re-application of a dab of Loctite and you're good.
I've never used (and never needed) copper grease on them. As said above, using grease and the standard torque setting will lead to overtightening and possible stretching of the bolts.
