Indicator switch gear
Dazza2910
Post by Dazza2910 »
Now that I've got the indicators on, the switchgear seems a bit temperamental. Indicator switch doesn't feel quite right and doesn't work 100% of the time. Full beam button is also a bit sticky.
Are they easy enough to strip and fix or best just to replace.
Electrics not my strong point so just thought I'd ask.
Daz
Re: Indicator switch gear
First off get yourself some contact cleaner, spray it in & around the buttons & work them in & out/side to side.
If that doesn't improve things then strip it down for a deep clean but be aware there are springs & small ball bearings in there, waiting to pop out & hide next to your 10mm socket never to be seen again... 8O
If you can find a replacement unit will it be any better ?
https://www.ebay.co.uk/sch/i.html?_from ... r&_sacat=0
Dazza2910
Post by Dazza2910 »
Thanks Mac. Bit of WD40 is all I've tried so far.
Will get some contact cleaner from work. Have seen switchgear on eBay for £20 or so that are sold as working so that's always a possibility.
Will have a look at it tomorrow.
Daz
