Starting bike
Fatbloke
Starting bike
Post by Fatbloke »
Hi i wonder if anyone can help i have just brought a 1998 firestorm and when i picked it up the bloke said to me when starter motor goes round it is slow because it is a v twin but when i got it back home the starter motor turns once then the relay just clicks and light goes out a new battrey was fitted in febuary i have put test meter on it and it comes up 12volt i have cleaned the bolt on starter motor made no diffrence but when i jump start it it fires up straight away any advice would be good thank you for looking
Re: Starting bike
it could be a number of things, personally i'd suggest looking at the reg/rec, they can be an issue on these bikes, if it's the flat style with no fins, then it'll be crap. change it for a later model finned style, or upgrade to a mosfet reg/rec
as for the starter motor, they're very robust, as long as the main connection isn't rusted. sometimes the main starter cable can corrode on the inside, heading back up to the relay.
but do a search on here about reg/rec issues first
Re: Starting bike
Just because the batt shows 12v doesn't mean all is well... When it's running check with meter it should be in the 14v range if not...R/R is fubar.
Or maybe the batt has dropped a cell. Try it with a differnt battery to start with...
I had the same issue, changed...Starter, starter cable, 3x starter relays...still no joy... Tried a diff battery & the bastid fired up first time ! :lol: :lol:
Fatbloke
Re: Starting bike
Post by Fatbloke »
Thank you i have a new battrey on order and starter cable and relay see if it works
Re: Starting bike
Fatbloke wrote: Sun May 26, 2019 9:20 am Thank you i have a new battrey on order and starter cable and relay see if it works
just be aware that if your reg/rec is faulty, it will kill your new battery fairly quickly.
