Coolant leak
Markie
Coolant leak
Post by Markie »
I seem to have a weep from the bottom connection with the coolant tank. It’s only located with a spring clip and possibly, the hose needs pushing on further.
How on earth do I access it????
Thanks
Re: Coolant leak
Remove / move out the way what's above the expansion tank . i.e tank, airbox.
Re: Coolant leak
And be careful not to snap the plastic choke connectors which screw into the carbs.
