Braided clutch line testimonials
VTRsquid
Post by VTRsquid »
Just wondering if there is a noticeable difference?
Worth it or spend it on beer? Search failed me.
Not cheap, about half the price of the three brake lines.
Re: Braided clutch line testimonials
VTRsquid wrote: Sat Apr 20, 2019 1:06 am Just wondering if there is a noticeable difference?
Simply fact is over time the OE lines will degrade & start to swell with the pressure...I doubt the clutch line is under as much pressure than the brakes when used but still worth changing it if only for the looks...
VTRsquid
Post by VTRsquid »
True,
Do they generally come in one piece, or do they incorporate the existing hardline?
I imagine with one piece you would pretty much be on your own coming up with tie down points?
Im thinking to get Wezmoto as its the cheapest one and will match the brake lines.
VTRsquid wrote: Sat Apr 20, 2019 12:59 pm True,
Yeah just a stright line... Just follow the old clutch line for the position, you'll see how the std one fits as you take it off...
VTRsquid wrote:True,
I fitted Wezmoto lines on mine and they are great value for money and a good finish Image
As there is actually very few rubber bits to the clutch line as most of it is a metal tube, so there will not be much difference when fitting a braided line.
Though the rubber bits that are there are starting to get a bit old so there is no harm in replacing it and braided lines look good :thumbup:
VTRsquid
Post by VTRsquid »
Cheers guys ill just pull the trigger on the clutch line then, will match the brake lines and give me an opportunity to unravel and tidy up the umbilical cord of tangled shite going up the left frame spar, most of which is the PO's wiring for the 3,000 modules and flashers and led strips which i have already dispatched either end of with the side-cutters lol.
I fitted one in my storm, there was no difference at all apart from the cosmetic improvement.
Haven't bothered on the SP2.
