Battery advise
scouse645
Battery advise
Post by scouse645 »
afternoon, i am messing about with the battery connecting a trickle charger cable, should i take out the main fuse while doing it?
Re: Battery advise
scouse645 wrote: Thu Mar 14, 2019 2:31 pm afternoon, i am messing about with the battery connecting a trickle charger cable, should i take out the main fuse while doing it?
Cant hurt but as long as you disconect Neg first then Poz...Put the Poz side charger cable & Poz batt cable back on first...
Or is it the other way round ... :lol: :lol:
scouse645
Re: Battery advise
Post by scouse645 »
ok thanks
Re: Battery advise
MacV2 wrote: Thu Mar 14, 2019 2:57 pm
I think you're right the first time Mac.
As I understand it by removing the earth (-) cable from the battery which is linked to the frame (or bodywork of a car/van etc) and/or engine you cannot accidentally short the battery out when undoing the positive (+) side of the battery by touching the frame or bodywork with your spanner.
Re: Battery advise
sirch345 wrote: Thu Mar 14, 2019 4:36 pm As I understand it by removing the earth (-) cable from the battery which is linked to the frame (or body of a car/van etc) and/or engine you cannot accidentally short the battery out when undoing the positive (+) side of the battery by touching the frame or bodywork with your spanner.
