Rear brake hose clips
Moderator: VTRDark
templ8
Post by templ8 »
At some point over the winter I've mislaid the 2 plastic clips that retain the rear brake hose to the swinging arm.
Does anybody have a pair going spare?
Thanks in advance
Sent from my ONEPLUS A3003 using Tapatalk
Re: Rear brake hose clips
More than likley...
I'll get Frank on the case tommorow to have a rake in clips & brackets draw...
If affermative you want the bolts with them ?
templ8
Post by templ8 »
No need for the bolts, just the clips will be fine.
Thankyou
templ8 wrote: Fri Feb 15, 2019 8:10 pm No need for the bolts, just the clips will be fine.
Thankyou
OK I will check tomorrow & get back to you... :thumbup:
In stock, PM incoming your way... :D
templ8
Post by templ8 »
Thanks Mac.
Replied
