inverted forks
VT1000r
inverted forks
Post by VT1000r »
im looking to buy some inverted forks for my vtr but i want to keep the original front wheel rotors and calipers does anyone know of some forks that meat those requirements that will fit on the vtr i can buy new lines cables and triple tree just want to keep those things.
Re: inverted forks
VT1000r wrote: Mon Jan 21, 2019 10:47 pm im looking to buy some inverted forks for my vtr but i want to keep the original front wheel rotors and calipers does anyone know of some forks that meat those requirements that will fit on the vtr i can buy new lines cables and triple tree just want to keep those things.
I think you'll find thats nigh on impossible... Anything can be made to fit but work will be required but keeping the std wheel & brakes...??? If thats a cost thing then I'm not sure you'll reach that goal...
RWU Blade forks keep the origional wheel but upside down ones require different everything...
& why would you want to keep the std brakes ?
VT1000r
Re: inverted forks
Post by VT1000r »
MacV2 wrote: Tue Jan 22, 2019 8:14 am
Oh the only reason I said that was because I thought that there were some that met those requirements but since there's not what are some inverted forks I could use and what all would I have to do to make them fit?
Re: inverted forks
Use the search (top right corner) to look for > upside down forks
VT1000r
Re: inverted forks
Post by VT1000r »
Wicky wrote: Tue Jan 22, 2019 10:06 am Use the search (top right corner) to look for > upside down forks
Lol, "duh" I don't think sometimes.
Re: inverted forks
Flatline
Re: inverted forks
Post by Flatline »
AMCQ46 wrote: Tue Jan 22, 2019 1:09 pm my conversion story
What were you originally then, Alistair?
Re: inverted forks
The 954 Honda Fireblade fits well, just the bars cause some issues. All relatively cheap to obtain as well
Re: inverted forks
Flatline wrote: Tue Jan 22, 2019 1:50 pm
i was confused :D
Re: inverted forks
AMCQ46 wrote: Tue Jan 22, 2019 9:15 pm
i was confused :D
Was Allison ?
Re: inverted forks
954 and 929 go straight in. complete front with no mods to bike or front end except maybe moving the bars to clear fairing.
i put a kawasaki 7R front in one last year but it took some machining and a stem swap.
mik_str
Re: inverted forks
Post by mik_str »
04-05 ZX-10R forks allow you to keep stock VTR front wheel, rotors and axle.
VT1000r
Re: inverted forks
Post by VT1000r »
mik_str wrote: Tue Jan 22, 2019 10:59 pm 04-05 ZX-10R forks allow you to keep stock VTR front wheel, rotors and axle.
Do you have to do any mods to headstock?
VT1000r
Re: inverted forks
Post by VT1000r »
AMCQ46 wrote: Tue Jan 22, 2019 1:09 pm my conversion story here viewtopic.php?f=30&t=14381&hilit=rsv4&start=105#p454627
Thank you for the link my kind sir
mik_str
Re: inverted forks
Post by mik_str »
VT1000r wrote: Tue Jan 22, 2019 11:46 pm
You'll need CBR600RR (USD) triples and have the uppers opened up by 2 mm to accommodate the tubes. You'll also need customs wheels spacers (19.5 and 25.5 mm IIRC)...
https://www.superhawkforum.com/forums/m ... rks-29622/
