Hazard light switch
TaxiDriver
Hazard light switch
Post by TaxiDriver »
Has anyone fitted a hazard circuit and is it even possible to do this?
Re: Hazard light switch
TaxiDriver wrote: Tue Jan 01, 2019 8:18 am Has anyone fitted a hazard circuit and is it even possible to do this?
No, Yes, Why ?
I see bikes with hazzard flashing when they are filltering...It's not really the correct use of them & as most cagers on the commute when in lines of traffic rarely use their mirrors anyway it's a bit pointless...
have a read of this...
https://mocktheorytest.com/resources/wh ... ng-lights/
TaxiDriver
Oh,good,to prevent being rear ended.....matron.
TaxiDriver wrote: Tue Jan 01, 2019 11:19 am Oh,good,to prevent being rear ended.....matron.
Ride with you lights on...Neither will stop the rear ender if the fekwit driving the car is not paying attention...
Simplest way would be to fit a second flasher relay with a push-to-talk or regular type switch, and connect both rears and fronts to just one side of the relay.
For filtering, you probably only need the front pair flashing.
E.Marquez
Post by E.Marquez »
Not hard to make it work, somewhat hard to do cleanly, not hard at all to do well if you have good experience with wiring.
Id use a electronic flasher, some diodes to isolate the new circuits, use a ON/Off push switch in a add on switch holder mounted to the clutch or brake master with switch holders from https://www.highwaydirtbikes.com/index. ... irt Bikes they have some brilliant parts usable on pure street bikes. Properly tie in to all four light circuits using new sealed type connectors from Furukawa, Sumitomo, Tyco/AMP, or Yazaki https://www.corsa-technic.com/category. ... ory_id=120
Marquez Motorcycle Services
Post event services
Total Rider
And advanced Rider training
