Rear shock
gabi81
Rear shock
Post by gabi81 »
Whats the standard length eye to eye 345mm or 348mm? As my nitron is 355
Thx
Sent from my SM-G950F using Tapatalk
Aha you know what it is black and yellow...black and yellow !!!
popkat
Re: Rear shock
Post by popkat »
Think it's 348 but not sure it's been a while since I measured on. Is the Nitron on it's shortest setting on the ride height adjuster ?, mind you if 348 is right and it's at 355 thats 7mm longer, not too bad, I'd live with that but make sure there's no spacer on top of the top clevis.
Re: Rear shock
im near sure they are 345 standard. i put the penske into mine and was told to run it at 348mm by a man that knows these things :D
Flatline
Re: Rear shock
Post by Flatline »
Aren't they 366.75? I'm sure they are
Rear shock
Flatline wrote:Aren't they £366.75? I'm sure they are
Sorry Flatty. We are talking about shock length, not what yours is worthImage
Flatline
Re: Rear shock
Post by Flatline »
Oye! I've just seen your reply, cheeky bugger :Ball Kick:
Re: Rear shock
346mm
Re: Rear shock
Flatline wrote:Oye! I've just seen your reply, cheeky bugger :Ball Kick:
