New home for the ladies
StormyRob
Post by StormyRob »
May seem small but I have wanted this for a long time. Moved house over the last few days. Best I have ever had is a shed and now the ladies have a garage which will soon also have electricity. Very very pleased indeedImage
Sent from my SM-G935F using Tapatalk
Re: New home for the ladies
Now's the time to rip the roof off and replace with something with a steeper pitch on another row of breeze blocks to make it higher.
Two major advantages:
You can build in a hoist strong enough to lift the bike off the ground
You can get enough headroom to be able to use a ramp.
Lastly, more storage space in the eaves.
Once you've fitted benches and filled it up it's too much work to do later.
Also, fit more strip lights than originally seems necessary, on the eaves as well as centrally above.
It means you never have to work in your own shadow.
StormyRob
Post by StormyRob »
I don't think the roof will be coming off anytime soon 😂
But strip lights will be going in. Can get them pretty cheap. Should do the job.
put the bikes in the house and all those who object into the garage :D
I'd be tempted to rip it down and build a bigger one with space for a sofa, tv, toilet, kichennette and then move in :biggrin Oh..and you better get rid of the weed growing in the garage before the cops come :lol: That roof looks like solid concrete. If you was to raise it you could use acros to jack it up, stick another layer on and then lower it back down. Make sure it's watertight before painting and installing electricks etc. Get a tin of damp seal and coat it all especially around base where the concrete DPC is. What about the other ladies, are they enjoying their new home.
StormyRob
Post by StormyRob »
It isn't even my house, just renting 😂
Yes mate the other ladies are quite happy. Much better than what we had.
At least you have a better space to work on them now Rob
Happy days Rob ,its just what you needed.. think how many storms you will be able to fit in that place :eek2
Martinz
Post by Martinz »
StormyRob wrote: Wed May 30, 2018 2:08 pm It isn't even my house, just renting 😂
Stormy Rob did you get my Private message ?
StormyRob
Post by StormyRob »
Martinz wrote: Sun Jun 03, 2018 6:33 pm
Sorry mate no?
