Hi there,
Been a bit of a lurker on this site for a while, picked up some great tips....however have not managed to find a solution to my problems so any suggestions would be welcome.
Riding into work today and started to notice a problem with my clocks after some heavy braking. Firstly they just died, everying was blank! But the indicator lights still worked. Then then started flicking about wildly, seemed to be more of a problem with revs on....speedo and revs back to normal at idle but the temp gauge was incorrect.
Not sure what I could have done to cause this problem, and suggestions welcome.
Regards,
JD
Clocks all over the shop!!
I will be the first thing I do at lunchtime, I am assuming there are various block connectors around the back of the clocks that need looking at...I just found it strange that the gauages were flicking all the way round the dial, with a loose connection I would expect either a reading or not, my temp gauge was at 2/3rds and static, which was the wrong reading as I had just set off.
James
Might sound like a daft question but your had'nt just washed it or been through rain have you?? just I had a similar thing once and it was damp in some of the connections, especially the speedo pick up at the rear of the engine block.
Just a thought
ian
P.S. welcome
Just a thought
ian
P.S. welcome
- essexbloke
