BLUE bike refurb log
TaxiDriver
Re: BLUE bike refurb log
Post by TaxiDriver »
Got a few more bits to add today.....
Had a visit from the legend that is BrianC today,helped to walk me through the time consuming
work that is involved to get to the really easy work of fitting the mcct's,just an out of tolerance valve to sort and then good to go.
Can you believe it,Hagon completely replaced all the metal work and then put the manky spring back on......
Does anyone know what type of throttle this might be?
Top man BrianC :thumbup:
I like the look of the parts on the bench, but not sure the new rad is going to go so well, especially if you're leaving it white :wink: :lol:
That throttle looks standard from the photo, but I'm guessing someone has added extended cables to it for your higher handlebars.
Did you find those brass screw type cable nipples on the ends of the throttle cables :?:
They're not a favourite of mine, I prefer proper soldered ones,
I ran a Hagon with a remote adjuster on mine for years, and when you get a refurb they replace the older design damper rod lower section with the latest version foc.
For a cheaper shock they certainly look after the customer.
TaxiDriver
sirch345 wrote: Sat Apr 14, 2018 10:13 pm Top man BrianC :thumbup:
Thanks for that Chris,Yes could just be for the longer cables.
Of course I'm going to paint it blue..... :lol:
Throttle looks like mine standard storm body with fire blade cables fitted for higher renthal bars
TaxiDriver
Duffy1964 wrote: Sun Apr 15, 2018 9:01 am Throttle looks like mine standard storm body with fire blade cables fitted for higher renthal bars
Cheers for that.................
BrianC
Post by BrianC »
I was just relieved to see its a blue one - and the proper shade as well
Brian
TaxiDriver wrote: Sun Apr 15, 2018 8:09 am
:lol: That should make all the difference :lol:
That's interesting to know Duffy, is there any particular year(s) that fit our Storms :?: obviously they'll need to be the years with carbs for a start :lol:
I think it was early 90’s blade models, it was Lloydie that gave me the info if I recall correctly
Duffy1964 wrote: Mon Apr 16, 2018 1:13 pm I think it was early 90’s blade models, it was Lloydie that gave me the info if I recall correctly Image
That makes sense as Lloydie had an early Blade that he Streetfightered :thumbup:
Cheers,
BrianC
Post by BrianC »
Im sure graham will be along soon to caution about buying chinese stuff !!!!!
Sorry graham - couldnt resist :wink:
Just pleased we got that timing sorted, and now its over to you to reconstruct - but im only a phone call wnd 15 mins away
Brian
TaxiDriver
Yea bloody thing,thanks again Brian for your time and input.
BrianC
Post by BrianC »
Always a pleasure graham
BrianC
Post by BrianC »
Great morning spent with graham today.
We got the carbs on - only problem being those damned solderless nipples needed on the extended cables for the raised bars
Plastic trims then airbox and i have to say came up with a blinder to fit that damned front breather pipe to the airbox - just disconnect it from the cam cover the fix it to the bottom of the airbox before trying to locate the airbox!!!! Then fit it back to the cam cover - genious!!!
So filter and airbox top then the tank - we couldnt find the pivot bolt!!!
Fairing back on and its looking like a bike again - just need to fit the forks now graham and its turn the key time !
Ps oil change first !!!
BrianC wrote: Sat Apr 28, 2018 9:58 pm Great morning spent with graham today.
That tells me that you haven't got the plastic plate fitted that goes under the carbs to deflect engine heat?
You will have just as much trouble trying to get the vent pipe to go through that if you connect it to the airbox first.
