Fork spacers (internal)
Moderator: VTRDark
popkat
Post by popkat »
Anyone got the spacers that go on the top of the fork springs, quite long ones don't know length but would guess about 100mm, They're the only spacers in the forks so you'll know.
Cheers.
Re: Fork spacers (internal)
No sorry but If you can get the correct length any old bit of tube will do... :lol:
https://www.ronayers.com/oemparts/a/hon ... front-fork
No3 they are out there around 12-14 for one...
If you can wait I'll measure one, prob next weekend tho... I just don't have any spare forks laying around for a quick measure...So its a full on strip down to find out...
Al & Fabio have just put new forks on so they should have the old forks laying about & easy to get to...
way in the back of my head 80mm rings a bell....
popkat
Post by popkat »
when I fitted K tech springs to the race bike I had to cut the spacer down 10mm, odd as I have K tech springs in my Storm and they popped straight in with the std spacers. I'm going to get some lighter weight springs so may well need stock length spacers.
Was hoping someone had an old bent pair of forks lying about that they could rob them from.
cheekykev
Post by cheekykev »
popkat wrote: Mon Jan 22, 2018 10:26 am Anyone got the spacers that go on the top of the fork springs, quite long ones don't know length but would guess about 100mm, They're the only spacers in the forks so you'll know.
Cheers.
I'm pretty sure they are 110mm long as standard and cut down to 100mm when upgraded, I'm sure someone will be along shortly to confirm.
Any pipe will do, even plastic pipe , that's what's in the SP2s.
Like what you do
Do what you like
macdee
Post by macdee »
A couple of red bull cans with the ends cut off :thumbup:
poppers il have a look today. i mite have something growing in the cave will do the very job.
popkat
Post by popkat »
fabiostar wrote: Tue Jan 23, 2018 6:25 am poppers il have a look today. i mite have something growing in the cave will do the very job.
Did you find any ?.. Took mine out today and they are 90mm, I cut 10mm off so originally they were 100mm
I may have some but will have to wait until Saturday when I can search the stock shed in daylight.
popkat
Post by popkat »
tony.mon wrote: Wed Jan 31, 2018 10:43 pm I may have some but will have to wait until Saturday when I can search the stock shed in daylight.
Steve97 Is sending me some :thumbup:
If I need any more I'll give you a shout, cheers Tony :thumbup:
