GrainStorm V
Re: GrainStorm V
Hi guys, I still need to fit the MCCT’s that I got from Bazza! If the bike makes it with the old ones fitted but it’s worth the risk to see you guys and get some professional advice and even help putting them in..
If we don't learn from our mistakes we are destin to repeat them
- alanfjones1411
Re: GrainStorm V
Brake and clutch fluid replaced
Re: GrainStorm V
if i can get the planets to line up i may get over for a spin
Re: GrainStorm V
No problem. It might be worth well in advance having a go at removing the large inspection cap on the Generator Cover. They are really soft & bugger up easy. Give at least an overnight soak with Plusgas & with the best correct size allen key try to undo it. IF it lossens off easily just nip it back up, better still clean any PlusGas off, then put some copperslip on before doing it back up but don't go mad tightening it.
Chances are it will round off. Fear not there are ways & means but it involves a big hammer & tends to muller the cap so go to Dave Silvers & buy a new one just in case...https://www.ronayers.com/oemparts/p/hon ... t7-000/cap this is US site but the part number is the sam £12-£15 +shipping.
Re: GrainStorm V
Just bring some fresh Dot4 fluid Master Braker Jonsey will be on hand to help you fettle your hydraulics.
- KermitLeFrog
Re: GrainStorm V
I'd really like to try and get to this. Being born and bred in Gravesend (well, actually born in Northfleet) I've got plenty of rellies in the area. Mind you, none on Grain, so they all have the regulation number of fingers and toes. I haven't been down for many years.
pm me your address and phone number and I'll put it in my diary. Can't promise like, and I'll not need any work doing, but you never know...
- alanfjones1411
Re: GrainStorm V
Your Barred with comments like that !KermitLeFrog wrote: ↑Sat Jan 13, 2018 9:07 pm I'd really like to try and get to this. Being born and bred in Gravesend (well, actually born in Northfleet) I've got plenty of rellies in the area. Mind you, none on Grain, so they all have the regulation number of fingers and toes. I haven't been down for many years.
Hahahaha No be good to see you if you can make it... PM on way.
Re: GrainStorm V
Thanks for the advice, I’ll be sure to make sure I give it a go well in advance to make sure I’m prepared.MacV2 wrote:No problem. It might be worth well in advance having a go at removing the large inspection cap on the Generator Cover. They are really soft & bugger up easy. Give at least an overnight soak with Plusgas & with the best correct size allen key try to undo it. IF it lossens off easily just nip it back up, better still clean any PlusGas off, then put some copperslip on before doing it back up but don't go mad tightening it.
Re: GrainStorm V
I still have my old centre caps which came off clean. Remind me closer to the day and I’ll bring them along for you.
Re: GrainStorm V
Thanks Kev, very kind of you. I’de be happy to pay for or replace any parts.Kev L wrote:I still have my old centre caps which came off clean. Remind me closer to the day and I’ll bring them along for you.
Re: GrainStorm V
They’re just sitting in my spares box. No charge.
Re: GrainStorm V
He says that Solar but be warned this is just the start...The common name for it is Grooming...He'll soon be telling you that you owe him & his blue helmet needs cleaning...he is colour blind he means purple...
