New handlebar
Varastorm
Re: New handlebar
Post by Varastorm »
Like the idea :thumbup: Cbr600 f4 forks fit the Varadero yokes.
I also know that the fork spacing of the Varadero yoke are closer together. You will need to remove 2mm off each wheel disc mounting face for the Vtr wheel & discs to fit.
If you don't, the disc bobbins will strike the fork legs :thumbdown:
Machining the wheel is only necessary when using Varadero yokes on a Varadero frame with Varadero or Cbr600 f4 forks & a Vtr front wheel :thumbup:
The above sounds silly but I don't know if the yokes fit/swap into other frames :thumbup:
Varastorm
Re: New handlebar
Post by Varastorm »
No idea how to remove the ignition barrel on a Vtr sorry.
Help will arrive soon I imagine :thumbup:
Re: New handlebar
to remove the ignition lock you need to grind the head off the tamper proof screws and then once the tension is off they will unscrew by hand. then replace with normal screws
Re: New handlebar
jzape2005 wrote: Wed Jan 03, 2018 1:32 pm
Varastorm wrote:If this works, I'd imagine it being an early candidate for Vtr modification of the year 2018 Image
Will the lower yoke fit also? It might be a stronger item than the oem Honda one Image
Good luck Image
Hi.
At the moment the only problem is to make the central hole a little larger, from 23m / m to 25 m / m. This afternoon I hope to have it done and ride it tomorrow.
Another obstacle is to be able to remove the ignition key. I do not see how to loosen the screws, do you know how I can get it out?
Enviat des del meu Aquaris M5 usant Tapatalk
They are security bolts the head snaps off when tightend up leaving a headless bit that no spanner or socket will fit.
Drilling them out is the only option, best use a pillar drill if you have one as you need to drill very straight.
grumpyfrog
Re: New handlebar
Post by grumpyfrog »
Or, cut a cross onto the dome, dremmel works fine here, and hit numerous times with an impact driver.
I tried the: drill a small hole at the edge and use a punch to try and drift it out. But nah that wasn't man enough.
If you can turn the head upside down onto tubes (old forks ideal, but I didn't have any and was not going to do it on the bike) it would be much easier.
I just made my young lad try and hold it on a bench.
And it's a normal thread..... I had to ask.
Don't hassle me
I'll get there at some time
jzape2005
Re: New handlebar
Post by jzape2005 »
jzape2005 wrote:
AMCQ46 wrote:To avoid cutting lots off your faring you need to keep the rise of the yoke and the new bars fairly low.
As you see Nellie I got the bar clamps just over 1" above the yoke then I used rental ultra low super bike bars.
They do a true flat bar which has zero rise and only a sweep back.
good job.
I see that we also have to cut the fairing a bit, luckily I have another spare but another color, so if I'm wrong I will not have a very big dislike.
This week I will post pictures of the work.
Thanks for your interest. a hug
Hi.
At last I was able to remove the screws from the ignition key. I have remembered several times about his family ......
Now we just need to make the hole in the center of the fork support, I have taken it to a workshop to do it centered.
Let's see if tomorrow I can start riding.
A greeting
jzape2005
Re: New handlebar
Post by jzape2005 »
Gentlemen in the end fit.
I have had some problem but the result seems satisfactory.
I have the doubt that handlebar place and solve all the rest, brake pump, switches etc.
Hope you like. a greeting.
I will upload photos when I have the rest of the material
Re: New handlebar
thats handy to know of another yoke option for storms :clap:
Re: New handlebar
Good job.
Does it have space for the ignition to clear the clocks?
jzape2005
Re: New handlebar
Post by jzape2005 »
tony.mon wrote:Good job.
hello, these days I have had work and I have not been able to work on the project of the handlebars.
Yesterday I received the new handle, it has a different shape than the one shown in the photos.
I touched the clutch pump on the fork of the suspension, when I mount the new handlebar I will tell you.
Now I have painted the seatpost and I have prepared almost everything to mount ..
Excuse my English, I know it's very bad.
Greetings from Catalunya, Terra Alta.
mdb
Re: New handlebar
Post by mdb »
Did you ever finish the conversion?
