Hi all, starting to get warm now in Brisbane for the city traffic commute and bike is sitting 100 to 105 degrees and getting tappety.
I run a 10w40 full synthetic that has done about 3000kms this service.
I think the commute is cooking the oil and as thinking about having the fan operating at on 95 off at 90. I can buy different thermofan switches but wanted to see your thoughts.
1. Temp range setting,
2. Thread size
Aftermarket switches come in 85 to 90 as well as above and a 14mm thread. Is this the right thread?
Dude.
Different fan temperature switch
Re: Different fan temperature switch
Hi me.
The thread size is apparently 16mm and the replacement needs to be short. The available aftermarket option seem to be brass. Not sure how the brass goes screwed directly into the aluminum radiator.
The superhawk forum has guys using a Nissan switch.
Me.
Me.
There's nothing like replying to your own questions
Sorry I can't advise you,
Worst part is when you don't agree and 'turn the tap off'.
I remember on my gs500, I fitted braided brake lines from BTR (over your part of the world -and good vendor too). Anyway, the copper washers started going funny where the made contact with the alloy master cylinder, should have kept the factory aluminium washers.
As an alternative, fit a bigger oil cooler.
The four row SP or blade one can be made to fit.
That works well when dealing with extra heat when using an ignition advancer or high comp pistons.
That are some how to's in the knowledgebase, and you can convert to braided oil lines while you're there.
Hmm oil cooler, hadn't't given it much thought. Looking at the size of the factory one compared to the coolant radiator, it seems like a token offering. I believe that oil transfers heat well so maybe that's why it's smaller. I'll take a look. For those that have done a bigger cooler, do you see any notice able difference?
Yes by several degrees..and it was a repeatable observation as I did the cooler swap on my first SH and noticed cooler running temps in stop and go summer traffic..... Rode my second SH stock for a bit, then swapped over all the good parts from my older one.... watched temps drop with just a cooler swap.
This winter slow season (I get to ride year round where I live) bigger radiators and a second cooling fan with its own temp switch go on.
Marquez Motorcycle Services
Post event services
Total Rider
And advanced Rider training
Post event services
Total Rider
Agreed, a noticeable difference.
When I fitted an ignition advancer and high comp pistons mine would overheat in stationary traffic if in hot weather, but with the uprated cooler it very rarely did it.
- alanfjones1411
Don't know if he still has it,but Kev L had an SP1 oil cooler and modified brackets and pipework for sale.
I like the idea of not loading the alternator up with more fan time and it looks like the oil cooler does the job. I'll keep an eye out for one out this way.
Thanks for the replies.
