Snapped plastic doodahs on carb
bigbadjonno
Post by bigbadjonno »
Hi,
I've snapped the damned plastic gubbins for the choke valve on the front carb. I've discovered that gl_s_r has sold a few in the past, but I can't message him as I'm not a big enough poster.
Any chance somebody could let him know or otherwise point me in the right direction to get hold of some please?
Re: Snapped plastic doodahs on carb
Stratman
Post by Stratman »
They are little buggers. Broke mine too.
They're plastic.
No need for a breaker bar.
bigbadjonno
Not through over-tightening unfortunately - I accidentally leaned on the front carb before I had seated it fully in the rubber, it just wonked over a bit and caught the elbow on the head somewhere. Rather a fragile little thing and Mr Honda wants £50+ for the valve assembly.
Judging by the demand for replacement parts, I'm not alone!
Cheers Wicky for the help.
mik_str
Post by mik_str »
chap called Jack Flash sells brass copies over on the Superhawkforum too if the other options don't pan out for you (what I am using)....
bigbadjonno
Thanks Mik, I've ordered the ones that Wicky recommended - heartbreaking paying 26 quid for a pair though! :cry:
mik_str
Post by mik_str »
bigbadjonno wrote:Thanks Mik, I've ordered the ones that Wicky recommended - heartbreaking paying 26 quid for a pair though! :cry:
cause you're paying for all that r&d.... :) BTW, you likely saved a gram or two of weight with those (compared to brass).... not to be discounted (sayeth he of carbon obsession), lol
