Well ..with 103k on her ..time for ground up
Elchappo76
Re: Well ..with 103k on her ..time for ground up
Post by Elchappo76 »
And slso ..do you yhink these look like std orig pistons .ImageImage
Sent from my SM-G900I using Tapatalk
Yes, they're standard.
Elchappo76
tony.mon wrote:Yes, they're standard.
Ok thank you.
Elchappo76
Ok thank you.
Also ..any ideas on why no 3 engraved here.Image
The bearing codes are written in white paint or engraved on the cases.
Have a look at the Haynes manual for bearing codes and what shells you need.
Same for big ends.
Big_Jim59
Post by Big_Jim59 »
What a great thread! Thanks for posting. It takes me back to my rebuild. Now I just ride the heck out of it.
Elchappo76
Thank you tony. Greatly appreciated.
Elchappo76
Well was just getting it all together to deliver to shop and i noticed this broken tooth on on gear ...can this gear be replaced aww is whole crank gone....Image
Elchappo76
All good ...
Elchappo76
Elchappo76 wrote:All good ...
Is this very common at all tony.
Broken teeth on crank gears?
Never seen one before.
Elchappo76
tony.mon wrote:Broken teeth on crank gears?
Well tony .. ive been a bit on the waiting side on deciding which way i go on this ..until i just discovered ..a 05 mod engine with 27k on it ..and a constant compression test resulting in a 165 psi . For $500 . So my question now is on installing man ccts . Image
