bar risers
mr dave
bar risers
Post by mr dave »
im thinking of getting these https://www.topyokes.uk/honda-vtr-fires ... lebar-kit/ if anyone has used these or similar can they tell me if they were able to use the original throttle cable, i can see that i would have to change the clutch and brake hoses i was just wondering if the original throttle cables have enough play in them or would i have to try and source new longer ones
Re: bar risers
iv had high bars on mine in the past and used a standard cable no problem, i had to re-route the cable a little but still had plenty to play with. :thumbup:
podman
Re: bar risers
Post by podman »
I would also ask the manufacturer, just to be on the safe side as they should be 100% certain one way or the other...
spanner boy
Re: bar risers
Post by spanner boy »
Just ordered a kit. I suspect the hydraulic lines will need replacing with longer but the rest should be ok depending on which bars you go for.
Re: bar risers
Yes std throttle cables will be fine with those yokes and a set of ultra low bend renthals.
I also have the std clutch hoses still fitted and had no problem with the Goodrich brake lines that were already on the bike before the conversion. The only think I needed to extend was the wiring to the horn
Re: bar risers
A word of warning, CNC top yokes may take longer in delivery times than as suggested on their site, as in could be a lot longer. Hopefully they are better now with delivery times, but in the past some of our members here have been waiting for weeks on delivery.
I will say though CNC's top yokes certainly appear to be top quality going by bikes I have seen them fitted too,
mr dave
Re: bar risers
Post by mr dave »
thanks for the feedback :thumbup:
