Early petrol tank tap and filter
Moderator: VTRDark
BrianC
Post by BrianC »
Has anyone got a good one of these?
After getting storm 2 going over the weekend , when i went in the garage yesterday i could smell petrol.
Today when i looked it was quite clear i had a fuel leak.took the fuel pipes off and petrol is still flowing out of the outlets so it looks like the diaphragm has gone ?!!!
Also the filter is in a bit of a state as well as the o ring.
So has anyone got a working tap and a good filter???
Worse come to worst i will have to buy a repair kit but a still need a filter
Thanks
Brian
Re: Early petrol tank tap and filter
You'll find that the fillters swell up so taking them out tends to fek them up...
Best buy a new fillter.
You can get repair kits which have a new diaphragm in the kit.
BrianC
Post by BrianC »
Thanks mac - thats whats happened to the filter.
Bit confused looking at those kits as they seem to have two sort of diaphragm pieces - mine seems to be one piece????
Or am i just confused !!!'
BrianC wrote:Thanks mac - thats whats happened to the filter.
Yes you are... Smaller one is on the inside IIRC so you cant see it untill you take it all apart...
BrianC
Post by BrianC »
I already had it to in pieces.
Is there a sort of piston thing the diaphragm fit onto?
Sure someone will have done this
If you've had it apart you'll KNOW there was a piston with a circular seal either side, and a spring.
Smaller seal inboard.
BrianC
Post by BrianC »
I didnt know if what looked like a piston thing was a part of the diaphragm, and i was afraid to start pulling it apart.
I presume the seals in the kit fit onto that piston.
Very sadly im not a storm expert and very unsure sometimes
The seals just push onto the stub on the smaller (nearest the front of the bike) side- pull them off the piston and you will see the groove where the replacement needs to sit.
We all learnt somewhere!
BrianC
Post by BrianC »
Cheers tony
