Front disk bolts
Moderator: VTRDark
Front disk bolts
Need about 6. Drop me a note if you have some you wish to part with
Re: Front disk bolts
He didn't shear the others.. ...gabi81 wrote:Only 6..?
said as it may be, i found the rest in my vtr nut and bolt box. must be time to by a breakertony.mon wrote:He didn't shear the others.. ...gabi81 wrote:Only 6..?
I should have some in the Frank stash.
I'll have a rake later & drop you a PM...OK
I think Gabi81 may be on the case. I will let you know if he doesn't find anyMacV2 wrote:I should have some in the Frank stash.
cheers
StuartWags wrote:I think Gabi81 may be on the case. I will let you know if he doesn't find anyMacV2 wrote:I should have some in the Frank stash.
cheers
You have a PM
Sorted TonyMons wheels now have discs and a set of wets on them..... just need to get the bike sorted
