Powder coating wheels, new bearings.
spawner
Post by spawner »
Hi All,
Im going to PC the wheels as they are nasty, and looking at changing the bearings due to the PC process, my question is are KOYO bearings ok? seen a set on ebay with dust seals inc sprocket carrier bearing for £43
not sure if its any good or not :crazy:
Darren
Darren
Re: Powder coating wheels, new bearings.
It's worth trying a local bearing factors. They're normally cheaper.
KermitLeFrog
Post by KermitLeFrog »
spawner wrote:Hi All,
Darren
Koyo are a good make. It's also a reasonable price. The sprocket carrier bearing is also not a standard (commonly used) size. I doubt you will save much at a bearing factor but you will probably waste a bit of time and petrol. I'd go with the eBay ones.
ps. The last bearing factor bearings I fitted didn't last for very long so getting them from a shop is no guarantee of quality.
bazza696
Post by bazza696 »
Darren
I bought replacement bearings for my newly PC wheels, front and rears without seals as I already had those but not for sprocket carrier came to £33.
Paultandy
Post by Paultandy »
Just got my koyo bearings of eBay for £30 as a full set front and rear with seals and the sprocket carrier bearing they were £35 or best offer Image
:beer: I drink beer like my bike drinks petrol :beer:
spawner
Post by spawner »
Paultandy was the seller motorcycle-online ??
Darren
spawner
Post by spawner »
Wicky don't suppose you have had your wheels done locally? or do you know if anyone has used impact coatings in Colchester?
Darren
Darren
I used Impact Coatings for a shock spring - they were pretty disorganised. The day I was was due to collect it it was still in the corner of the office untouched where I'd left it. Though when they eventually did it they did a good job.
Ater that experience I used Wheel Worx http://www.wheelworxrefinishing.com > Units 8-10, Oyster Park, Greenstead Rd, Colchester, Essex, CO1 2SJ :thumbup: Cost £140 to do the pair in black.
Universal Tyres are just round the corner along Hythe Quay so they took the tyres off and back on after coating.
Paultandy
Post by Paultandy »
spawner wrote:Paultandy was the seller motorcycle-online ??
Yes it was pal good service and fast delivery
spawner
Post by spawner »
Thanks all :D
Wicky impact quoted £45 + vat per wheel, would you still use wheelworx?
Thanks for replys
Darren
Darren
spawner
Post by spawner »
Thanks ordered some now :D
Darren
Darren
spawner wrote:Thanks all :D
Thanks for replys
Darren
I'd use em (Impact Coatings) if I wasn't in a rush - I think the shock spring was because it was a small fry job for em hence why it took 3 weeks to do (Wheel Worx did em in 3 days). If you've got any other bits that need PC you might as well get them done at the same time, plus pin them to a time scale and explain clearly what areas need masking for when they prepare them. IIRC Chemically stripping > grit blasting > masking > powder coating. When you get them back and before you fit bearings give them a good hosing out as grit gets everywhere.
spawner
Post by spawner »
Thanks for replys
Darren
Cheers Wicky I will give them a go.. when I get the bike back lol
Thanks again
Darren
Darren
bazza696
Post by bazza696 »
Thanks for replys
Darren
Thanks again
Darren
I used Intanations Ltd in Sible Hedingham, Halstead. They have done work for me on rocker covers for cars and have been very pleased.
They quoted me £100 for both wheels in gold, but they delayed in getting them done(3 weeks) but eventually I only paid £40.
