newbie
newbie
morning all im mark from sunny hull in east yorks just picked up a mint 97 storm for a grand ,pics soon .ive had all sorts of bikes from a hand me down mobylette at 11 years old.i mainly restore 70,s 80,s hondas like the sl,xl.xr range but this the vtr appeared on local bumtree ad so i thought yeah why not,ive liked the sound of v twins,i owned a tl1000s 6 years ago ,stonking motor on them .took it for a blast yesterday although a bit wet and cold.first impressions are favourable i like the low down grunt and it makes you grin when the front wheel goes skyward.the bike is totaly stock so too quiet for me so ive bought some delkevics off flea bay,i can live with the vibes as im used to big trailies,but the clip ons have gotta go,im a builder so suffer a bit from joint ache and white finger,so will have to do a handlebar conversion,reading some posts on the forum it seems you have to chop the fairing to accept certain bars ,unless you fit straighter drag bars am i correct in saying this i really dont want to get my hacksaw out,big fun tho, you seem a friendly ,knowledgeable bunch ,ride safe all,marko
Re: newbie
Welcome to the club Mark, I think you will enjoy the bike, especially if you do a flat bar conversion. That will make it feel like a 1000cc supermoto..
I did the flat bars on mine and I love it, don't know why I did 10yrs with clipons!! I think it is faster on the roads with the better leverage and visibility, and it wheelies better
I know you need to trim the fairing if you don't use straight "drag bars", but the ultra low bend renthals give you a much better riding position, that is still sporty but comfortable. Use a dremel with 2 of the thin cutting discs bolted on at the same time when triming the fairing and you won't even know it is not standard.
Have a look here
http://www.vtr1000.org/phpBB3/viewtopic ... 45#p240524
Have a look here
Re: newbie
welcome to the forum mark, I too have been looking to do a bar conversion. when removing my mirrors I noticed the fairing would flex quite a bit outwards away from bars, which might allow the fitting of renthal ultra low bars. someone with your knowhow it might be worth looking at as it would save cutting the fairing.
- alanfjones1411
Re: newbie
Hello and welcome to forum Mark.All the chaps on this site make for a friendly bunch and fully loaded up with knowledge on the vtr.All will help with any problems you may have along with a bit of friendly banter.Enjoy the most under rated bike Honda has ever made imo.
Re: newbie
Greetings
First sort the CCTs and R/R!
Was it you? > Lemon yellow storm Humber / Beverly Friday midday http://www.vtr1000.org/phpBB3/viewtopic ... 19&t=39860
Re: newbie
thanks for welcome boys,just wondered amcq46 what yoke did you buy?cheers mark
Re: newbie
Welcome to the club mate. Get the cam chain tensioners sorted and the regulator/rectifier changed to a later model finned version or a mosfet.
- alanfjones1411
Re: newbie
Fit manual cct's if not already fitted as auto cct's have a habit of failing causing bent valves etc.and upgrade to a mosfet regulator/rectifier or the later finned type as these fail and fry the battery plus other electrical damage.Both jobs are relatively simple and help is always available from the forum.marko wrote:nah wasnt me mines black cct..r/r?
Re: newbie
thanks for welcome again will check motor to see if mods have already been done.ta marko
Re: newbie
Alright, Marko?
I have an early SL125 with less than 7K on it that I'll finish rebuilding one day....
Technically it's the wife's as I spent her engagement ring money on it
Post up a piccy of your work.
Re: newbie
marko wrote:thanks for welcome boys,just wondered amcq46 what yoke did you buy?cheers mark
i modified a spare std one, but i wouldn't recommend if you don't have a mig welder and a milling machine to hand
Re: newbie
Welcome aboard buddy
I used VFR800 Bars as a straight fit, just trim the fairing a bit
Re: newbie
Hi and welcome,recommend the bar conversion it makes a massive difference to the bike also the cct I got mine from bazza and the reg rec is a gamble I didn't bother with mine then it fried the battery a long way from home enjoy the forum it's full of good advice and some tasty bits often come up in the sales section but ya have to be quick with this lot
