Checking a standard rear shock
Ant
Post by Ant »
Managed to get the spring taken off the rear shock today. Has anyone got any tips on how to check the damper now the springs off?
The damper rod looks all good, no pitting and no leaks but it seams really hard to push down is that normal?
NB this is probably just a paranoia post! :D
If it's broken; should it move? Yes: Use WD40 No: Use cable ties. Now it's fixed!
Re: Checking a standard rear shock
That's not something I have really taken any notice of.
Anyway a quick run up to my workshop to check has revealed that my standard Storm shock minus it's spring does take a fair amount of force to compress it, then once compressed to my surprise it extends back to full length all on it's own under control,
HTH's
Ant
Post by Ant »
Cheers Chris,
Thanks for checking. I was supprised when it sprang back as well. You'd think the spring would have that covered.....
Can now get the spring coated and reassembled. :D
E.Marquez
Post by E.Marquez »
It is a sealed and listed as non repairable item, though technically it can be opened op and serviced, just takes adding a charge port. (EDIT.. just to be clear "just" was an understatement, you JUST have to find and mark the correct spot, drill and tap and then install a schrader type valve rated at 300 psi or more.)
Not much to check though.
As you noted, no oil leaks, no pitting on the rod.
The shock should exstend fully at a moderate rate (with no spring mounted)
The spherical rod end should move freely (not loose, but move with moderate effort), no stiffness, catches
Marquez Motorcycle Services
Post event services
Total Rider
And advanced Rider training
Ant
Post by Ant »
Cheers marquez, I'll give that a check. Ant
Ant wrote:Cheers Chris,
Yes, that was what I was expecting,
E.Marquez
Post by E.Marquez »
Shock is charged with nitrogen, helps keep the fluid from foaming in use. Also is part of the overall preload.
Post event services
Total Rider
That makes sense :thumbup:
Ant
Post by Ant »
Ahh that makes a lot of sense! Cheers marquez.
But then it would be uncontrolled and behave like an ejector seat. The spring is more for damping than rebound.
