Put vac hose on wrong place now won't run
Please help had tank off to hide hid ballasts between frame and air box and I put vac hose on tank breather instead of on the petcock now it will start cold on choke but as soon as I touch throttle it dies thanks in advance for assisting in my stupidity!
Re: Put vac hose on wrong place now won't run
Greetings
Make sure the vacuum hose is on the fuel tap connection at the back pointing sideways NOT on the one pointing down. Plus if you turned the tap off turn it back on again.
- alanfjones1411
Welcome to the forum.Wicky wrote:Greetings
Welcome to the club fella.
Put hose back on 9 oclock position and turned fuel tap anti clockwise as far as it will go sounds like its not trying like no fuel going through
Take a fuel hose off and suck very gently on the vacuum hose - does fuel flow?
Tried that no fuel coming through so I turned fuel tap other way still no joy
Have you opened tank cap and tried?
Got fuel to come out of petrol tap but still won't run
paulb75 wrote:Got fuel to come out of pet rock but still won't run
Haha that will teach to check the auto spell before hitting post!
It's a good job you didn't post pet c ock. It wasn't a typo it was the forum swear filter. petcock would be better
Can you confirm that this is how you have it connected.
You may want to check that the vaccum hose is connected to the rear cylinder alongside the rear carb rubber. It may have come off there in which case it would not draw a vaccum.
Cheers will check it as soon as I can
Running sweet again now thanks the pic was a great help vac hose was hiding behind frame I had the breather on the left of pic connected as vac hose doh!
Wow I'm glad the pic is still useful
I chuckle when I see the copyright bit Carl. Well done!
Everything good is bad
Everything bad is good
