Brass exhaust seals
Brass exhaust seals
Here's a nifty idea to replace the pesky graphite exhaust seals with brass ones.
http://www.mv-motorrad.de/fr/MV+Exhaust ... radero.htm
Edit They're quite expensive but according to this thread someone has used modified sintered bronze bushes instead.
http://www.honda-varadero-uk.org/forum/ ... pic=8941.0
macdee
Re: Brass exhaust seals
Post by macdee »
How does it seal wicky
Is the graphite softer and crushes a bit
Good idea using a bronze piece with less waste
Good idea that. Spacers that's all that is required they don't have to crush as cheapo exhaust sealant can be used which 9 times out of 10 is required anyway. Now who can make some of these up then. :biggrin
Demonic69
Post by Demonic69 »
What are the dimensions needed?
If anyone has one to measure to double check
OD 48.5 X ID 42.8 X Length 20.5 mm
Demonic69
Post by Demonic69 »
So this could be turned into 2 then?
http://www.ebay.co.uk/itm/AM-405050-40x ... SwPhdVTNGc
