Hi, Im thinking of getting a gear position indicator, been looking at the Gipro X-type, has anyone got one and where is the speed sensor?
Tom
Speed sensor
Re: Speed sensor
Speed sonsor is mounted on the back of the motor...right hand bottom of the rear head IIRC.Tom O wrote:Hi, Im thinking of getting a gear position indicator, been looking at the Gipro X-type, has anyone got one and where is the speed sensor?
Tom
- agentpineapple
Re: Speed sensor
I've got one of those on my bike, it's pretty much plug and play.Tom O wrote:Hi, Im thinking of getting a gear position indicator, been looking at the Gipro X-type, has anyone got one and where is the speed sensor?
Tom
Re: Speed sensor
I fitted the datatool gear indicator to my old storm it took about an hour and half to wire it in to the back of the dash. Then you have to set it up about 15 mins Back end on paddock stand and I strapped the grab rail to the roof joists just in case it wanted to go through the garage door then go through the gears as instructed all set up OK
And it's still lying around in the garage somewhere.
Wanted yellow donor bike
Re: Speed sensor
Many thanks to you all who have replied to my post. But what is an IIRC, sorry not that technical yet.
Tom
Tom
- agentpineapple
Re: Speed sensor
IIRC= If I remember correctlyTom O wrote:Many thanks to you all who have replied to my post. But what is an IIRC, sorry not that technical yet.
Tom
Re: Speed sensor
agentpineapple wrote:IIRC= If I remember correctlyTom O wrote:Many thanks to you all who have replied to my post. But what is an IIRC, sorry not that technical yet.
Tom
- bazzashadow
Re: Speed sensor
has anyone got a picture of where to find the speed sensor
and do these gipro`s x types work ok
thanks
thanks
Re: Speed sensor
Back of the engine by the CCT - sensor lead leads up the subframe beneath the rear plastic cowling to a connector nr the battery where it plugs into the main loom. Emerges again to connect into the clocks.
