Anybody upgraded to a SSD hard drive?
Please use this forum to ask our resident IT geeks advice.
Virt
Re: Anybody upgraded to a SSD hard drive?
Post by Virt »
MacV2 wrote:
Virt wrote:
MacV2 wrote:
Virt, the balls on my abacus are sticking & not sliding along corectly, what do you recomend to speed things up ?
Will an SSD help me :confused
The only thing that can help you is a psychiatrist.
Thats the sort of answer I like...
Can you PM me the phone number of the one you use please... :wink:
Nah, he couldn't put up with me and stopped answering my calls :( he'd have no chance with you :lol:
Sent from my PE-TL10 using Tapatalk
I want to know what are you doing sticking your balls on the abacus in the first place........ 8O
This should do the trick :D
KermitLeFrog wrote:Always do a clean install if you can. The only problems I've seen have been upgrades.
Cheers Kermit :thumbup:
KermitLeFrog
Post by KermitLeFrog »
Doing one now and the bloody thing has stuck....
KermitLeFrog wrote:Doing one now and the bloody thing has stuck....
try Vaseline
KermitLeFrog
A hammer more like!
I'm guessing that will be an upgrade, not a clean install :?:
I will say when I upgraded from Windows8.1 to Windows10 I was amazed how well the transition went, much much better than I had ever expected,
KermitLeFrog
Yup. Upgrade.
Finally got it to work with an ISO burnt to a DVD and then telling it to ignore unsigned drivers. Need to clean it all up tomorrow. CBA now.
Well done mate, glad to hear you got there in the end :clap:
I've been and got the new SSD, I'm looking forward to seeing how it goes.
It's like the one below, hard to believe how tiny they are:-
UPDATE
I have now installed the new SSD into my desktop pc. I cloned my original HDD rather than installing W10 from scratch mainly because I have a few programs I wanted to keep that came pre-installed with the pc, but I have no software for these, so a clean install would have meant losing them.
I removed and backed up all my photo's, video's and music before doing this, so basically I just cloned the operating system to the new SSD. That part went very well taking just under 30mins.
Now the part that hasn't gone as planned is the increase in operating speed. I have set the SSD to maximum performance in the Magician software supplied by Samsung and enabled RAPID mode. I've tried different settings from the Samsung software, and anything I've thought worth a try from searching the Internet. The best I can get is knocking 5 seconds off the start-up time, and slightly quicker shut down time, programs like Adobe photoshop open in slightly shorter time, and I can run a scan (IE like Malwarebytes) without any loss in speed whilst browsing the net which I couldn't using the original HDD. Apart from those relatively small changes that is it.
So rather a disappointing experiment so far, unless I'm at fault by missing something :?:
Any advise chaps would be appreciated :?:
What you don't have a hard copy on windblows to install 8O Sorry couldn't resist.
Don't be too disappointed Chris, give it a week of use as SSD's tend to get faster with use until they reach their peak. The controller on a SSD needs to know what to prioritise so they learn with use. Have you set any kind of trim or does the OS takes care of this. I'm not sure how that works out with PC's.
Carl, you've lost me on the Windblows bit :eh: is that what Apple Mac users refer to Microsoft Windows :?:
TRIM is enabled and working. I did check that my pc supports trim before buying the SSD.
Cheers for your thoughts :thumbup:
I'll see how things go,
The windblows and the windoze...Oooo it gives me the chills :biggrin
How's it going you should noticing a difference, any improvements?
You need an extra jumper mate :biggrin
The system seems to be a little steadier, but not much more has happened. Definitely nothing like others have reported to experience in speed increase,
