Link pipe OD measurement
Not being near my bike would anybody know the OD of the link pipe ends for a Scorpion slip-on can system??
Re: Link pipe OD measurement
Would it be the same for other aftermarket slipons? I have the micron pipes sitting here
Best measure it for your particular system if your sizing it for the replacement clamps - as diameters can differ depending on if gaskets are used or not. I've had to use different sized clamps when either using stock, micron or moriwaki link pipes.
Normally 52mm
Damn was hoping you were going to say 50.9mm. Still at 52mm SP engineering can sort my links to fit their cans. These guys look like they do a really good job and have has some really encouraging reviews.lloydie wrote:Normally 52mm
http://www.spengineering.co.uk/xjr1300-99-03.html
- bigtwinthing
Mine were 51mm.
What exhaust system was fitted??bigtwinthing wrote:Mine were 51mm.
- bigtwinthing
Powertech Performance cans and s/s downpipes with Powertech Link pipes.darkember wrote:What exhaust system was fitted??bigtwinthing wrote:Mine were 51mm.
51 is doable probably actually 50.9 but i do believe the Scorpion systems are 52 just to be awkward so one cannot slip anything else onbigtwinthing wrote:Powertech Performance cans and s/s downpipes with Powertech Link pipes.darkember wrote:What exhaust system was fitted??bigtwinthing wrote:Mine were 51mm.
- bigtwinthing
yes you can, on flea bay you can buy a 3" long pipe thats 52mm 1 end and 51 the other. I had some for my Bulldog. £24 posted if i remember correctly.
Hunt me that down if you can find itbigtwinthing wrote:yes you can, on flea bay you can buy a 3" long pipe thats 52mm 1 end and 51 the other. I had some for my Bulldog. £24 posted if i remember correctly.
- bigtwinthing
i will have a look this w end.
