What to mess with first?
Hi All
So I got my first Storm home yesterday, here is a picture;
Bad points - yes it is about three different shades of blue and the exhausts are standard.
Good points are that it has manual CCT's fitted and a newish Bridgestone back tyre.
The paint on the front mudguard is crazed badly so i was thinking of wrapping in black to match the hugger, has anyone tried wrapping one before?
My bike wants a new home
Re: What to mess with first?
Good that it has MCCTs - but before the pretty stuff:
Check that the R/R is a later finned version, or better still a MOSFET.
Service the swingarm shock linkages.
Check under the rubber hood on the starter motor for corrosion.
Give it a service / change fluids.
PS.
Move the bin when taking pics of your new StormBeastie or try experimenting with vinyling it ;-)
PS.
Good call on all points
I am going service it at the weekend so will check the rec and starter at the same time. I will save the swingarm service for another day (i.e once i have read the sticky on how to do it).
Off to wrap the bin lid, has some similar curves to the mudguard
+1 on Wickys' recommendations
Also, I tried wrapping the front mudguard and it was very tricky, even with expensive vinyl and an extra pair of hands, it was a failure of epic vinyl wrapping proportions!
But, you may have more patience than myself...
Jamie
Ideally i want to paint the whole bike (i hear Teal is popular ) however my painting skills are poor, so I thought i might try wrapping until i have funds to get the whole bike painted by someone else.
- agentpineapple
what wicky said, give the bike a good once over. I've dabbled with vinyl wrap in the past, with patience it can be done well. but if your wanting black, it would be easier to paint it. where are you based?
Fixed it for you Wicky & Welcome to the Madhouse stuffedit...Wicky wrote:Good that it has MCCTs - but before the pretty stuff:
Give it a service / change colour.
Don't fit TAT !
PS.
Put all the blue bodywork in the bin then paint your new StormBeastie RED or try experimenting with vinyling it in RED;-)
- alanfjones1411
Most important first job is paint it red.Anyway welcome to the forum.
Not so fussed about all black, just thought it would look a little better if the mudguard matched the black hugger and wrap is relatively cheap.agentpineapple wrote:what wicky said, give the bike a good once over. I've dabbled with vinyl wrap in the past, with patience it can be done well. but if your wanting black, it would be easier to paint it. where are you based?
Once I have done all the service stuff (and the linkages), after the mudguard next thing to be 'fixed' will be the exhausts.
Don't you listen to the heathen ba@stards matey, and certainly don't consider slowing her down by painting it red, or worse still adding black into the mix!
Take your time and stick with the brotherhood of blueness my friend.
Hello and welcome .
Once you start tinkering with it 'you'll never stop !
I don't mind the blue, it's just the different shades that offend me!Kev L wrote:Don't you listen to the heathen ba@stards matey, and certainly don't consider slowing her down by painting it red, or worse still adding black into the mix!
get the exhaust changed and enjoy the sound ,and tuning wise just paint it yellow for instant sex appeal
Going to have to wait for payday for the exhausts, been alerted to a set of high level ones on eBay(thanks Alan), hope they don't sell and they get relisted for another week or so.fabiostar wrote:get the exhaust changed and enjoy the sound ,and tuning wise just paint it yellow for instant sex appeal
Yellow mmmmm....
If your thinking of wrapping then a bit of heat will help to shape or just look up a company that will do it for you, might be cheaper to get it sprayed black in the first place rather than spending money out on wrapping first. If you were to sand and prep it yourself then the paint shop wouldn't charge as much. Or you could cover the postage and I'll spray it for you, have 2k panther black already.
