cbr 600 calipers
10robbo
cbr 600 calipers
Post by 10robbo »
hello all,
can anyone say if cbr 600 F F3 calipers will bolt straight on to vtr, is it a good upgrade. and to fit cbr master cylinder or stick with original.
thanks
Re: cbr 600 calipers
It's F4 callipers you want & no they dont bolt straight on you need to remove some metal from either the lower fork bolt mount or from the calliper body.
10robbo
Post by 10robbo »
thanks for that know what to look for now, would you use cbr or original master cylinder
10robbo wrote:thanks for that know what to look for now, would you use cbr or original master cylinder
Yes.
See here for more info...
http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=15494
or sp1 or sp2 calipers, also fireblade 1998 thru to 2003. as with the cb600f4i they'll need a little adjustment.
10robbo
Post by 10robbo »
yes think it may have to be f4 as they seem easier to find, doesent matter shaving a bit off as they all look like they will need painting.
still unsure on which mc to use
10robbo wrote:yes think it may have to be f4 as they seem easier to find, doesent matter shaving a bit off as they all look like they will need painting.
iv just done the blade transplant with master cyl and its a good improvment :thumbup:
StormyRob
Post by StormyRob »
Ive been learning a lot from the guys on here. A few in particular. The f4i m/c will be fine and will allow you to use your storm lever. I have sorted myself SP1 calipers and the f4i master.
