Why?
- freeridenick
Why?
Just read a tip in Bike magazine for removing ethanol from petrol. Easy as making instant coffee but what they didn't explain is why one would want to. Anyone know?
Re: Why?
Not sure if it has any effects on running but if you have a plastic fuel tank it causes the tank to expand and can cause bubbling in the paint. 1 of the downsides of owning a rsv or an older triumph like the 955i.
Sent from my SM-A300FU using Tapatalk
- carmanbikes
Re: Why?
Ethanol is corrosive to some seals and plastics it also absorbs water, I think it is more for older vehicles and classics, but if it stops water getting in by removing it may be worth doing before a winter lay up but I would just empty the tank
Re: Why?
The USA are on 20% ethanol and have a lot more problems than us at the moment as we are on 10% but I believe that UK will be going up to 20% shortly
Plastic tanks expand and rubber component will dry out and go stiff
I have added a link to look at http://www.briggsandstratton.com/eu/en/ ... n-fuel-fit ![Thumbup :thumbup:](./images/smilies/icon_thumbup.gif)
![Red Face :redface](./images/smilies/redface.gif)
Wanted yellow donor bike
- freeridenick
Re: Why?
Interesting. That's my new thing for the day.
Removing it is simply a case of adding water, shaking until the water and ethanol bind then decanting the petrol off the top.
Re: Why?
Very interesting. According to "Whatcar.com" ethanol is used to reduce greenhouse gas emissions, but it also says it reduces power from petrol:-
http://www.whatcar.com/car-news/new-e10 ... ts/1229022
Re: Why?
When I had a Triumph speed triple, the seal on the tank perished due to petrol ( oddly enough )
- firestorm_al
- Site Admin
- Contact:
Re: Why?
My Aprilia Falco had a non metallic fuel tank that "grew" over time as a result of the ethanol affecting it. I ended up getting a spare fuel tank as a back-up. The swelling was bad enough to make it really difficult to get the tank to fit back onto the tank and can get bad enough to damage the seal between the bottom of the tank and the fuel pump.
Al.
Al.
