Vaping
kev64
Vaping
Post by kev64 »
Bought one of these bad boys on Saturday.
Started off not too bad, had a couple of fags here and there but not many.
Today I have had non and its getting to me a bit.
I'm about to walk down the shop and get 10 fags !!
Any vaping tips would be greatly appreciated :confused
Vaping
Best tip I can give you is to bin that one and buy a better one .
I use a kangertec sub tank and a cool Fire IV battery , I run it at about half power 25watts and it give lots of vapor and a nice smooth pull .with this set up you take it directly to lung .
Tho this is a good set up
http://www.ebay.co.uk/ulk/itm/252141848301
Find a good shop for your juice , I use big juice as its smooth and comes in lots of nice flavours .
The tobacco flavours are nasty tbh regardless of brands .
With the set up above you want no more than 11mg nicotine or you'll be on your butt .
kev64
Re: Vaping
Post by kev64 »
mine aint too bad, lasts about 2 days before flat,
and am running at 3.8v !!
whatever that means :lol:
kev64
Re: Vaping
Post by kev64 »
am using tobacoo flavour, 10mg
makes me go a bit dizzy now and again
(wonder if theres some extra ingredient in there :thumbup: )
Re: Vaping
You'll burn the coil out in a week .
When it tastes nasty change the coil if you can .
I used a aspire etc-bvc tank on a ego battery like the set up you have there for a few weeks Imagebut soon wasn't enough and I wanted a smoke even though I had 18mg nic init .
I'd use up a coil every two weeks in it and the battery lasted two days
kev64
Re: Vaping
Post by kev64 »
I was hoping to get rid of the nicotine in
a couple of weeks anyway,
but stay on fruit flavours, don't suppose it will
work out like that though.
met a women in the shop that had been on 24mg
of nicotine for the last 2 years !!
simo
Re: Vaping
Post by simo »
Live and learn. I didn't realise they were high tech like some of them. Need to do ones homework before buying.
Theres A Hare in The Turnips.
Re: Vaping
im on a ospire esp.. big baby only needs charged every 4 days. i mix a few diff flavours ,im on 12mg and wouldnt go back to cigs. i enjoy my vaping and total cost each month is £10..
or put it this way. since the start of the summer vaping has bought me. a set of tyres. a belly pan, big brake kit. airfilter,two oil changes , brake pads and iv still saved a few quid..
kev64
Re: Vaping
Post by kev64 »
I must admit I wouldn't mind if I got hooked on this.
like to kick the fags at my age !!
just off 2 bed now, made it through day 1, yipeee !!!!
( hopefully with all the money I save, ill be able to afford an sp2 soon :thumbup: )
chric
Re: Vaping
Post by chric »
lloydie wrote:Best tip I can give you is to bin that one and buy a better one .
what makes these type better?does it still sting throat etc started vapeing my self again but still smokeing
Saintsman27
Re: Vaping
Post by Saintsman27 »
Keep vaping them fags will see you off :thumbdown: good luck :thumbup:
Re: Vaping
All depends on the juice you use and what strength it is . The juice I use is very smooth .
Two big chugs and it's like a full fag .
kev64
Re: Vaping
Post by kev64 »
Been doing a bit of reading on this subject last night,
seams theres upgrades and everythin !!
Will need to look into good juice shops as well .
Llyodie, how long does a bottle last, I used mine since Saturday,
and still have some left in the bottle !
Re: Vaping
I buy 30ml bottles for £8 and it lasts me a week ,
It all depends on how much you use it tbh .
You can mod them but it's better to buy a good one to start with as it'll be more than enough for a long time .
You also need to think about coils when buying one as some you will find it hard to find replacements.
I can get two weeks from a coil for my kanger tank , I buy a pack of 5 for £11 .
StormingHonda
Re: Vaping
Post by StormingHonda »
I gave up smoking for 7 years sadly started again in May, I'm currently weening myself off them this week to give them up again by next Monday.
The worst part is the Habit not the nicotine, you need something to take yourself away from the rolling, holding the roll up/cigarette, after a couple of weeks your kick that part, the nicotine would be fully out of your system.
I don't see vaping as a good way to give up, your still taking something into your lungs, who knows what this is going to do to your lungs in 20 years.
